TurboTalonAwd95
- 134
- Jun 15, 2006
Glocester,
Rhode Island
Ok so after putting a rebuilt head in my car and it not starting after like 2500 in parts and labor from a mechanic, i was reading that you need to bleed the lifters...so i took them out cleaned them exactly the way the vfaq said to and when i put the paper clip into the hole to depress the valve and pump them they wont budge AT ALL!! i thnk maby a few move a 1/16 of an inch up and down but shold they be this hard to move?? and to top it all off the paper clip broke off inside the lifter.......damn.... so my questios are
1.) should they be this hard to pump and 2.) since i screwed up of of them will a set of
1g lifters fit on my 2g head? or should i just go 2g stock or revised...thanks for any help guys...this car is giving me HELL!!
, 2 of them move half way, and the rest are good. Just pick the best 16 from yuours and mine and you should be good. I had them sitting in brake cleaner for a week so they're already cleaned and everything. It may or may not have bent the valves... For the most part, your cam shafts do the major valve moving.
