Injector Seals
Splitpi
1,204
28
Sep 13, 2005
Des Moines, Iowa
I just purchased a set of Evo 8 injectors. I had planned to replace all the seals, but I noticed that clear plastic sleave circled in red in the picture below are cracked on 2 of the 4 injectors and broken off on another. I kind of suspect this is normal due to the nature of the injector being awash in fuel and heat. Any one have a part number or know where I can get a new seal for the clear peice? I have the other seals already from this kit from Import Evo which contains the upper and lower O-rings.
Thanks
P.S. this isn't an actual photo of my injector, It just one I found online to represent what I mean.
When I got my injectors cleaned and balanced they also replaced that part for me as part of their service. You could give them a call/email www.rceng.com
Wish I had known this earlier because I have one that was broken and bought another injector to replace it. Now I'm stuck with an extra injector with a broken part that is fixable. :notgood:
