cas block off
racemygsx
57
Feb 26, 2006
Madison, Wisconsin
I am going to remove my cam angle sensor and was searching for some sort of block off that is made for this application. I am removing the cas since I am going with a different type of timming and want to make the engine look cleaner. I don't just want to put a plate over and bolt it down, since this will allow oil to eventually leak out. Any help would be great. I could make a custom plate, but want to see if it has been done already. I did search, but nothing came up. Thanks again.
Mmmm.....What did you plan on going with if you dont mind me asking??? Im not sure of anything ouyt there that will allow you to eliminate the CAS other than Haltech or some big time engine management system where you can have a magneto type trigger that gets a crank angle signal (similar to a crank trigger on a 2g) that can pull the timing signal from elsewhere but is kind of senseless when you already have one, and i cantt think of why you would want to anyway? And it especially wont work if you plan on doing this with stock ecu.
Joe
SBR
