bazza2541
- Aug 15, 2005
Letterkenny,
Europe
I have been offered, EVO 3 16g turbo, exhaust housing cracked, Will my 14b housing work?
Also EVO 3 Head, will it bolt to my 6 bolt block?
If not will the cams work?
Can I split the EVO gearbox from the EVO transfer box and use the EVO gearbox with the transfer box from my Laser? Will this keep all diff ratios the same? and will it bolt up?
FYI, Inlet and Exhaust manifolds, injectors, Head, Gearbox and Diff, Turbo (with cracked housing) and downpipe for 1200 sterling ($2000) Is this a good deal?
so I'd say don't buy the EVO goodies cause I can't think of any good reason for you to use them.
