Gregory
- 296
- 2
- Aug 22, 2005
Malvern,
Pennsylvania
Hey everyone. I was just thinking about how everyone bashes on the stock 2g plastic bov, and was wondering why Mitsubishi engineers made this switch. Well, I actually always kind of had a suspicion that they did this for a reason. I have no proof, but I figure it is a nice safety feature for the engine internals. If any of the turbo management components malfunctioned and caused too much boost, the bov would leak it instead of it being forced into the engine. For example, arguments vary about how much boost you should run with the stock fuel system on a 2g. Most say 15lbs, but some say as low as 12lbs. Well, when I first threw on a 1g bov without a boost controller, my boost went from 13lbs (where the 2g bov leaked) to 16lbs (umb, too much). Now, this was with the boost solenoid restrictor removed, so dont worry about the numbers. But I was thinking about how the 2g BOV kept me out of the dangerous range. I know this is solved with a boost controller, but I figure, theoretically, someone should want a bov that leaks just over the amount of boost they run. If you run 15lbs, you want it to blow at 16lbs. If you run 22lbs, you want it to blow at 23lbs. And when Mitsubishi engineers designed a car to run 11psi (or w/e the stock boost level is), they knew it was a good idea to have a bov that leaked at 13lbs. With that stock boost level below 13lbs, it not only seemed okay, but a smart way to protect your engine with a leaky bov. Of course, they are useless to anyone who wants to raise their boost, but on a stock car, its a nice safety feature, and a good idea. Just a thought
I heart dsms.
-Greg
-Greg
I don't think most manufactures of cars think their cars will last more than 7-10 years... most people don't even change oil at proper intervals for crying out loud.
You can't really overboost that thing. Plus, if it was designed to leak you'd have a major boost leak and be overspooling the turbo to make what little boost it can leading to turbo failure.
But that was probably at 3500rpm.
