Wizeman76
- 47
- 15
- Aug 29, 2005
Wales, United Kingdom,
Europe
Here's the deal. I've turbo'd a N/A EDM eclipse, using a stock 14B turbo with stock wastegate actuator (vacuume line hooked directly from the J-pipe to the actuator).
From startup, either warm or cold, I'll go for a drive and car boosts fine to the standard 7psi of the wastegate. After around 30 seconds of running awesome, the car then will only boost to 3psi. If I turn off the car and let it sit for about 30 seconds, then turn it on and go for a drive, the same thing happens again, full boost for 30secs then only 3psi after that.
Any ideas??
Any ideas??
