Quick Power
LuLusTurboTalon
31
Sep 27, 2006
North Wilkesboro, North Carolina
I have a 92 Talon TSi and I was wondering what is the quickest way to gain horsepower without spending alot of money:talon:
Search and you will find your answer.
First and foremost though. A full maintence session would be great. No boost leaks,base timing all those good things first. I know they are boring and all to do, but must be done to keep it running top notch.
Those electric superchargers on ebay are freekin' sweet! :rolleyes:
Search please. There's even upgrade paths ON THIS SITE. First and foremost is maintenience. DO NOT SKIMP. Second, boost gauge, IS A MUST.
Then, typically. . . intake and piping, exhaust, uicp and licp if you want. Boost gauge.
Why am i reciting stage one power mods. Ugh, just look for the upgrade path.
quickest way to make power = nitrous
^^not the safest or correct way to start off, just trying to answer your question
the quickest way is to add more boost. this is, of course, after a full tuneup (plugs, filters, oil), a boost leak test and a compression test. once thats all taken care of (no boost leaks), then crank up the boost. there are limits to what you can do with the stock fuel system, get a boost gauge and a manual boost controller and set it to around 14psi, if you get a fuel pump rewire you can venture to 16psi but i wouldnt do that unless you have something to monitor timing/knock/o2 voltage, like a pocketlogger setup. you can also work on your airflow mods/bolt ons (Intake, IC pipes, Exhaust) as well, those are all pretty cheap points. thats pretty much as far as you can go on a cheap budget.
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
