pur97tsifwd
- 331
- 2
- Jan 31, 2006
Nevada,
Missouri
ok i bought a 93 eagle talon awd and it had alot of problems when i bought it i just got done replacing the clutch with a sbr 3500 and fidanza flywheel and other stuff all new clutch parts and clutch pedal the works the there is 3 gauges in the car right now that have not worked for a long time the oil pressure, fuel, coolant temp and also the turn signals dont work. Also the high beam light is on but its not on high but when i put it on high the light goes away the car has had the evo 3 motor swap i put a new oil pressure sending unit in the car b/c it didnt have one bought a new flasher relay and the were the coolant plugs in on the thermo housing there is 2 sensors and i only have one wire none of the new stuff i bought didnt help i will try and get pics of the thermo housing to show you all what i am talking about also the high beam light flickers sometimes off and on
