tkelly27
- 1,712
- 27
- Mar 11, 2007
Gresham,
Oregon
I need a new head for my 4g63 talon. I've found an 89 4g61 engine in a junkyard. Will this head work? Will the valves be able to handle the turbo abuse? Everything appears to be exactly the same, but I can be retarded sometimes and when "4G61" is put into the search engine only 2 hits show up. Thanks in advance!
*edit*
Ok, I found this. Anyone else had similar experience? Will I need to swap out valves?
*edit*
That's what I have on my car. You could just slap it on and go. But...
The main problem I saw was that the head was designed for a 82mm bore, so the sides of the combustion chamber overlap the piston on the sides. I highly recomend gasket matching the head to the headgasket. This will unshroud the valves and eliminate hotspots in the head. So far I've run 123.7 mph in the 1/4 mile on 96 octane gas.
Thanks for reviving this thread, I didn't have this head when the thread was started.
Oh wait, I just realised I have a 4G61 head on my car. It's off a early 90's Mirage. What is a 4G67 head from?
