Cold start problems 2 gn 6bolt
lancerevo3
Mar 18, 2007
borculo holland, Europe
My name is marcel van Dale from Holland Europe. My grammar will not be perfect but i do my best.
I have the following problem i recently converted a 2 gen eclipse GS 4g63
from a 7 bolter into a 6 bolter galant vr4 evo , i changed the motor mount etc pump relais wirekit etc intercooler etc. i have done the airflowmeter conversion from the 1 gn to the 2 gn
the engine works well but the problem is that when i do a cold start it has to be started for at leased 5 times and after that it runs like a dream.
I have done the following
Changed the stepper engine
checked the Ecu cleaned all the connecting pins
checked if there was not a wire broken
the problem now is that the stepper motor sometimes works to, and then it starts direct and sometimes not i have adjusted the trottle sensor not the TPS
put on another ecu from a non turbo than the engine starts direct, put on another turbo ecu MD 150427 it starts but this is i think an ecu from a normal vr 4 turbo with the 450 cc injectors and not the 510 cc so i am not sure if i can use it any ideas
some pictures ps does any one has a wiring diagram for a 2 gn i have to put the Airco in again but dont now what exact wires
http://i7.photobucket.com/albums/y282/venemaaai/Afbeelding163.jpg
http://i7.photobucket.com/albums/y282/venemaaai/Afbeelding128.jpg
here is another GS i have build
http://www.cardomain.com/ride/486477
This is my hobby lancer evo 3
http://www.fotoforum.ru/kingofeurope/participants/P6250122.jpg
greetings marcel
Can,t remember , the car is already on it,s way home so i can, t look at it at the moment
( it,s a ### motor i parly rebuild it ) i building on the moment a mirage 1993 gti with a 4g63 non turbo and i took the EGR off it has made a mess off the engine
    • sanmantsi72
    • El_marto
  • For sale 1G DSM 4G63 PARTS
    • The_Partout_Spot
