data logger
It's just a device that plugs into the cars diagnostic port and lets you see what the sensors are telling the computer. Most of them are just a interface with a cable that you plug into a palm pilot. This will let you monitor/record the motor as you drive so that you watch for stuff like the timing, throttle, air flow, etc.. It is really one of the first things you should buy when you start modifing ng your car. Do a search you will find almost all you need to know
  • For sale 2g 97-99 Mpi relay
    2g. 97-99 Mpi relay. Many don’t realize the later 2g doesn’t use the same mpi as the 90-96...
  • For sale 2g 2g window moulding
    2g pass side window moulding. Rubber is in decent shape. Has one dent. Front plastic end cap...
  • For sale Mishimoto Intercooler
    Universal Mishimoto Intercooler $100.00 Brand new
    • jmt2028
  • For sale 2g Mahle Power Pak Pistons
    2g Mahle Power Pak Pistons, factory bore $350.00 Brand new with wrist pins and extra set of...
    • jmt2028
  • For sale 2g Water Neck/Thermostat Housing
    2g OEM waterneck and thermostat housing $60.00 In good condition, came off 1995 Eagle Talon Tsi
    • jmt2028
