Boosted19
- 276
- Dec 4, 2003
Bethlehem,
Pennsylvania
Aright heres my dilema... It only does this once in a while. Only in fourth gear on the highway the clutch will slip mabye 2 or 3 times a week. It started it once I started to run more boost. But my question is why does it slip only once in a while? I already have a clutch and a flywheel to go in. But just want to make sure nothing else is wrong. The trans shifts liek butter so its not the master. Becasue that would cause harsh shifting. I dont think the slave is leaking at all. Only mod I did with the hydraulics is the restrictor mod. And put in dot3 synthetic fluid.
Also would you guys reccomend replacing the clutch fork since my trans will be out for the clutch? And if so what kind is good?
Thanks!
Thanks!
