Zmann42087
- 840
- 21
- May 9, 2005
Portland,
Oregon
I've been doing a lot of reading on here and it has spawned some questions. I know the EVO O2 housing flows better than any DSM O2 housing (1g or 2g). However, is it necessary to port an EVO O2 housing to eliminate boost creep on an EVOIII 16g? Yes, I know to eliminate boost creep on an EVOIII 16g you need to port the wastegate flapper area and the stock O2 housing to decrease the "turn" into the wastegate entrance. I'm just wondering if the latter part is needed even with an EVO O2 housing. If porting is still necessary wouldn't it be better just to pocket the $100 for an EVO O2 and port the hell out of my 2g O2?
Also I have questions regarding the EVOIII exhaust manifold. I understand the EVO manifold has a larger collector that matches the 7cm exhaust housing on a 16g. Is it worth the $150? If didn't get the EVO manifold, should I port my 2g manifold to match the 16g's 7cm hot side?
