90tsistorm
- Jun 5, 2006
Wisconsin
Ok well i got my timing belt change done and I was wondering what you all thought about this. So i take the cover off and notice that the bs belt was just slipping on the pulley system no matter what. Come to think of it it look like it had been slipping for a while seeing as no teeth were on the belt. So im thinking the shaft is stuck and it's worthless to put a new one on as that will do the same. So should I put it back on or just leave it off?
P.S. it is the front shaft if you are looking at the motor from the driver side.
