max boost a turbo can push
Status
Not open for further replies.
levee000
Jan 9, 2007
Cedar Park, Texas
i have a 91 gsx and i have a stock turbo pushin 14psi wats the max it can push its a tdo5h stock 1st gen turbo thx
The turbo itself can do 20-21psi, but without fuel mods I wouldn't push your boost past 16-17 psi.
It all depends. There are people pushing 20psi with the appropriate fuel system, intercooler, etc.
ok well were rebuildin right now as we speak with 2g pistons and a basic rebuild shit so i was jus wonderin but were doin the right fuel system and everything one time LOL hopefully
ok well were doin a 255lhp pump and fuel reg and maybe some bigger injectors and tune it with jus a 3 in turbo back exhuast it became alot faster so i wanna see what it will do now with a higher compression w/2G pistons
hint hint wink wink... I need to upgrade my injectors, I have 550cc and need to go to 650cc+. Decide if you want to keep the 14B or if you are going to a larger turbo before you make your injector decision. The pistons will raise your compression a little so pushing more boost without playing with timing and fuel maps can get risky.
Status
