crazy_skier
- 246
- 1
- Jan 26, 2006
Alexandria,
Minnesota
I took my car for a spin today to get some gas moving through it after letting her warm up and when I got on it, she pulled and spooled really fast, so I checked the boost gauge and it was up to 26 psi (I run 16 right now) so I let off really quick and then it happened. my egts now wont come up over 350 or so (celcius) and I peaked at 810.
and I was right by my house so I decided to limp it home the block and a half. I was having to run 50-70% throttle to keep the rpms around 2500-3000 in first gear. so my question is, did I just blow my plugs (to cold to check -20 right now..... brr) or did something else really bad go wrong (like melt a piston
) there was no coolant that I saw around the head which is good unless its under the intake manifold. I was not able to get the engine to rev past 3000 except for a couple of small blips - and I was getting black to light black smoke which I never get. please help asap as I need to get this thing running
Thanks alot Ryan
) there was no coolant that I saw around the head which is good unless its under the intake manifold. I was not able to get the engine to rev past 3000 except for a couple of small blips - and I was getting black to light black smoke which I never get. please help asap as I need to get this thing running Thanks alot Ryan
