dsmfreak555
- 54
- Dec 7, 2006
kailua,
Hawaii
To all you dsmlink users out there how accurate is "estimated afr" feature in dsmlink. will be picking up a wideband with dsmlink but when you use water injection doesn't your wideband read wrong cause the of steam in your exhaust??? a local supra guy down here said that when he installed his meth kit his tuner said that you have to tune it differently cause the steam affects what the wideband reads is this true? if so then I gues I would have to use the estimated value for afr if its decently accurate.
Something I never thought of though is to use race gas with meth injection and tune to something aggressive like 12:1 or12.5:1 afr then go back and use water injection and pump to keep that afr even though the wideband won't read it at that afr if indeed the water injection skews your afr readings.
With water injection you can lean out you afr, gaining a little bit of power cause all that fuel in there is only there for cooling(to supress knock) and get a little better gas milage(well with less fuel making the same power anyway)
Wiseman please correct me if I am wrong in anyway, I read alot of material at once and sometimes the info gets mixed up in my head
