Auto transmisson hard parts
91 Eagle AWD
34
Jan 15, 2006
wichita, Kansas
I've called IPT for the front oil pump and they are out, they said to get new from dealer.
Called three dealers,and looked at online dealer. They all say not available.
Short of buying a used tranny where should I look? Part # MD735137 91' a/t awd:talon:
I would try a local trans shop as they have connections to used parts .
Have all the tranny numbers with you if you go to one.
One place is Slauson Transmission Parts in CA. but they are wholesale only
So you would have to go thru a trans shop with a account with them .
What is wrong with the one you have ?
If it is all chewed up there will be shavings in the valve body and the rest of the tranny also ,because this is after the filter .
I broke the ears off mounting it to motor :coy: ,found 5 pices. No shavings or trash in oil.
Took small magnet and grabbed the five and took off TC seal and did not get any more metal. Was thinking by the time I get it out of the shop, I could just buy a used JDM for around 450.00 with TC & transfer case. Thanks for your help!
