Timing on logger fluctuating from2-17* at idle, please EXPERTS I am completely stuck.
90 GSX
322
2
Jun 24, 2004
Fremont, California
The car has a stuttering problem at low throttle and high rpm (>4000). It also has a bad miss at idle. Sometimes the engine almost dies. At WOT it doesn't hesitate at all (or it's just so light I can't feel it) but it has lost a lot of power. I have been trying to fix this problem for months. I have almost literally replaced everything having anything to do with fuel/spark including but not limited to:
Coil (twice)
Transistor (twice)
Plug Wires (three times)
Plugs (three times)
ECU (twice)
CAS (once) - verified correct phase by putting engine at 1-TDC
I even replaced the entire damn engine wiring harness. The car has NO boost leaks at all, not even a small peep at 20 psi on my gauge. I have verified this about 7 or 8 times so don't ask me to check again. Timing is 5* btdc, but the timing light sometimes misses/jumps around even with the timing connector grounded and the datalogger unplugged (the car was NOT in idle adjustment mode). This brings me to my newest development in this bi*** of a problem...
My timing at idle fluctuates from as low as 2* to 17*!!!! For some odd reason I just noticed it today. The engine rpm fluctuates with the timing and I have a feeling that it's a cause rather than an effect of this problem. The weird thing is, the car still misses, but when the radiator fans come on, the timing stops jumping and settles around 9*. Another thing I believe is crucial here, is that the car accelerates fairly (still missing but only slightly) smoothly to about 4000 rpm but after that it sounds like a broken speedboat putting in water or a fart machine gun or something, put put vvvvv put vvvvv put put put.
Anybody? For me, this problem is completely :beatentodeath: :beatentodeath: :beatentodeath: . Over the last few months I have examined every aspect of the car and found a bunch of minor problems I didn't even know I had like a bad batt, bad connections, etc. but now they are all fixed, but my car isn't. I am ready to drive it off a cliff... At one point it ran so damn well, for about 3 weeks then everything went downhill. I swear the car was so fast, it was probably faster than my supercharger trans am at 17 psi. This all started as a power loss, then evolved into a miss at all rpm with a loss of power. I can probably describe miniscule scratches on the surface of my multimeter at this point.
HELP!!!!!!!!!!!!!!!!
Im not sure about your problem maybe something to do with fuel. I used to have a injector that would go in and out for some reason. Finally died on day. Also with the timing fluctuating this is normal when not WOT.
The idle fluctuation seemed to be a fluke I guess it's not doing it any more. I was in the carl's junior drive through for about 10 or 15 minutes and the idle only missed but didn't fluctuate erratically.
How do I test if my injectors are working properly? Can I probe the wire while the car is running or how should I do it...
