KeithL322
- 42
- Oct 6, 2005
Clarksville,
Indiana
Ok so heres the deal... I start my car.. and I can SMELL it running lean at idle my a/f gauge shows it too... then it will slowl climb into stoich.. .i know the 02 sensor has to come up to temp to read correctly... so heres where it gets weird...if i fiddle with the gas then let it idle again once its at temp, it will register stoich for a sec, then go all the way down into lean, and then off the a/f lights further lean...and my vac is supose to be at 20... but most the time it is at about 17... but it fluxuates between 20and 16 alot... ok. next part...my idle...when the car is running well is at about 1100..high i know... but i have to set it that high because when the vac goes up to 17 or so the idle will drop to about 700-750...first thing i thought was boost leak, but that would make me run rich, which im not...so i dont have any clue what it can be, oh and also, anytime i turn on ANY accesory, lights, or heat the vac will drop even more and my car idle will drop even more and stay there and all of my gauges and lights inside will get dimmer.. when i give it gas and its not at idle its fine...only thing I could possibly think of is Im running off the 02 sensor housing atmcause my downpipe came off of it somehow, i already got a new gasket and the bolts for it though, does anyone have any clue what else it could be??
thanks for all help in advance
as an update i just reconnected the o2 sensor housign to the downpipe and put a new gasket in... although it is still leaking a tad(already put a gasket from autozone on there and used the old nuts, and it leaked like crazy..until it came undone!...bought this gasket from dealer and got new nuts to strap it down, leaks just a little now) i had a oil leak on my oil feed line that i jsut got done fixing (hopefully) as well, there is a small like of oil on the outside now once i started the car again, but it doesnt look like its actualy leaking any, ill just have to drive it a little and see.. bu tanyways back to the car... i actually satarted it again before i put the 02 housing on, and this time it smellt rich! i went to look at a/f gauge and it was sitting in the middle of the rich section, and rpms were correct...shut it off... started it back up about 20 seconds later.. . af gauge back to lean and rpms low again... i really am starting to think it is my alternator!.. are those things a pain to take off and put back on? never changed anything that has a belt strapped to it yet! (ei. alternator, power steering, ac compressor, water pump! :/ )
