PCValve or NO PCValve
4g63telantra
454
2
Dec 10, 2004
Toronto,
For the people running a catch can to the PCValve,
Do you still run a PCVvalve to the catch can or did you remove the valve and just added a fitting to the catch can?
PRO'S & CON"S on both set-ups and why did you runn it this way
Thanks
I removed my PCV valve, tapped the head, installed a fitting, and ran a hose into a catch can. In between the valve cover and catch can, I installed a $2 fuel filter to catch excess oil. Then i ran another hose into the intake pipe before the turbo. Never had a problem since I did this, and no oil gets into my turbo and intercooler pipes.
