LTUDSM
- 1,802
- 7
- Jun 27, 2005
Morrisville,
Pennsylvania
yesterday i did a gm maf setup,so i need help on my reading i don't know more than half what are they meaning cause im really new into gm translator
here is my readings: sorry if i wasn't clear enough
AF-LO @RPM @400 +2.0%
MAF sensor 100g/s+1.0%
Min Rpm 3136
min load 166.4
lean lim 8%
rich lim 8%
gain 4
Afr 2000R 11.5
Trig@rpm @400+4.5%
sensor monitoring:
load 25
Afl in 4
HZ in24
HZ out49
tps v 0.67
Afterstart 100,0
Afr Des 11.5
spark 16.0
Spark Adv:
Wot spk@rpm @2000 16.0
Config setup:
load source use Maf/Rpm
displacement 2.16
system settings:
idle flow 1.7
idle filt 2.00
af tr delay 0.0
Min Rpm 3136
min load 166.4
lean lim 8%
rich lim 8%
gain 4
Afr 2000R 11.5
Trig@rpm @400+4.5%
sensor monitoring:
load 25
Afl in 4
HZ in24
HZ out49
tps v 0.67
Afterstart 100,0
Afr Des 11.5
spark 16.0
Spark Adv:
Config setup:
displacement 2.16
system settings:
idle flow 1.7
idle filt 2.00
af tr delay 0.0
