Alphahookups
- Jul 26, 2006
San Diego,
California
My girlfriend bought a 97 gsx that was modded but had stock injectors and the afc set to zero so that it would pass smog. We recently reinstalled the 660's and I was in the process of tuning it when the egt probe broke. I bought a replacement probe from TRE but it hasnt got here yet and the car is running like shit. It is running rich to be on the safe side, but my girlfriend says it bogs hard when she trys to accelerate, and then it finally gets going. I think the basemaps are set to somewhere around -20 across the board for low throttle and -45 across the board at high throttle. I know these probably seem strange, but I am new to DSM's and I had a buddy help. Now that I think about it, it seems like the low throttle should be leaner and the high throttle should be richer.
In either case I need a little help setting some "safe" settings.
The setup is
Greddy FMIC
3" Turbo back
Frank2 turbo
660's
Thanks a lot guys.
Alpha
The setup is
Greddy FMIC
3" Turbo back
Frank2 turbo
660's
Thanks a lot guys.
Alpha
-45 is good for 780s!!
), but wouldnt setting the AFC to ~31% across the board be the same as installing the 450's. I mean running 660's @ 69% is equivalent to running 450's injectors, correct?
I was going to say that.
