Rough IDLE problem
twocanewayne
159
Mar 5, 2006
clarksville, Tennessee
Hey , got a quistion. My 95 TSI AWD has started to idel rough when I have it in drive or reverse. It was before friday smooth all the time. Whats the problem u think.. Thanks in advance for any input:thumb: :talon: And I did search first, maybe a boost leak? Maybe a vacuum leak?
I'd check for vacuum leaks by running the motor at idle and spraying the vacuum lines with carb and choke cleaner and seeing if idle changes. If it does, start replacing the offending lines.
What kind of vacuum do you pull at idle?
Keep us posted,
A.
But isnt that kinda Hi though??Thats 48 lds at 1k on the tach. I thought 20 lbs was the norm. do you think its a boost leak? I can only boost 5 or 6 psi w/a t25 hooked up straight to the ecu.
I searched and I am hoping it is reading something called hkpa. It must be or something isnt right...any clues??
  • For sale 1g 90 Oil Cooler
    • kyler021
  • For sale 4G63 (Broken) Cusco MZ Center LSD
    Selling a broken Cusco MZ center LSD (not a Tarmac) for DSM/Evo123. This unit failed a magnaflux...
    • Canadian_CD9A
  • For sale 1996 Eagle Talon Tsi AWD - RaceCar Shell
    Rolling Shell
    • Black_Cat_DSM
  • For sale Neat gearbox 4 spider conversion
    I picked up two spare sets of spider gears for a 4 spider conversion as I wasn't sure what the...
    • tstkl
