pocketlogger wont register
ekizenbe
89
May 21, 2005
stony brook, New York
hey guys i have a plam m130 and its running legit version of pocketlogger. one day the battery died completely and i had to reinstall the program off my mini sd card. i copied the software from the card to the palm and started the program. now when i put my code in the box the software wont accept the code. the unregistered text still comes up on the main menu, anyone know how to fix this?
Are you the origional owner or did you buy the system from a friend/buddy? If you are the origional owner - or know the origional owner, go here: http://www.pocketlogger.com/index.php?pid=reg
If not you are SOL...Sorry. Unless you can prove you have a legit copy you are up a creek without a pocketlogger :-(
EDIT: Unless someone on here has a key generator in which case i want it too!
You wish..:cool:
You must have the wrong registration code..Follow the link weaselhack gave you, to get them to send you another one. But, If your hotsync name and cable serial number that you submit doesn't EXACTLY match (including case)the one we have on file, you will not receive your registration code..
There's other options for datalogging then pocketlogger though. Check out
http://mmcdlogger.sourceforge.net/
http://www.dsmtuners.com/forums/showthread.php?t=230375&highlight=loggers
Good Luck!
