fwdturbobov1996
- 1,504
- 8
- Feb 27, 2004
Blue Springs,
Missouri
Ok so my wheel bearing went out. Wohoo. Replaced the whole hub. Not even 10 miles later, its grinding again. I dont think its the wheel beargin cause well, its brand new. Whenever I make a left or right turn it cause the rotor to be pressed against caliper. Its actually shaving metal off the rotor. Its beyond annoying. I dont konw what else to replace. I have replaced the stock kit with a wilwood kit, which is now ####ing ruined. Also replaced the hub and wheel bearing. What could be the problem? Tie rod end cause this? Ball joint? any help appreciated.
Car makes no noise in a straight line, just when making hard left or right turns.
