dsmoverboosted
- 217
- Feb 26, 2006
Winnipeg,
Well I just got my tial 38mm in today and I hooked my bike pump up to it to make sure it works good (bought it used) and it opens fine but it does leak boost. I assume this is not suppose to happen. It leaks from the shaft of the valve where it goes up to the spring. Is there something I need to replace or can I compensate it with maybe using a boost controller without a bleed hole and use the leak as a bleed hole?
Also there is a very slight gap when the valve seats. It doesent look like it will effect anything since it is so small (The only reason I know its there is because I can see a very tiny bit of light around the rim of the valve) but I thaught I would mention it anyways.
Thanks
Thanks
