carsaval
- 115
- Oct 18, 2006
Yukon,
Oklahoma
ok i live in oklahoma and man its cold, well i put 93 octane gas in my car from a station that i had never been too but its 93.3 octane
. well since then my car has started on the 3rd to 6th crank. And its running rich as heck, you can smell the gas, the spark plugs have a white arm and a black ring. its stock as far as intake and egr etc. my battery is a 550cca so i think that should be enough. I dont know whats wrong. ANy help is by far appreciated. BTW once the car warms up it drives like normal boosts fine everything I think i should do a compression test though what should the commpresion be on a stock 7 bolt ?
. no vacuum lines are loose, so my next try is a different battery im going to try to use the one from my moms van that should do the trick, BTW my profile says im running those things , WELL I actually have them in my possesion, but they are not installed yet I want the car to be running perfectly before i install something.
