flamingsqu1rr3l
- 42
- Aug 18, 2006
Lake in the hills,
Illinois
Whats up guys? As many of you have probably seen my previous threads, i have a new problem for the most part. My old 14b was starting to go, so my friend had a bunch of turbo parts for me for 600, so i took em. i installed a t3/t4, performance tubular exhaust manifold, external wastegate, fmic, and blow off valve. i had my o2 sensor housing off until i got it welded, but i first noticed that the car was running pretty horribly, and i thought it was the o2 housing. First the car was over boosting, and it wasnt set right. i took off the mbc and now its boosting to 16. also, it kept jerking, and the bov wasnt going off, the spring was too tight, so i put on a stock 1g bov... works freaking great. now, i still notice that i have some idle surge, and if i rev it up a little bit, when it comes back down, it goes a little higher than normal idle, then really low and it bogs and wants to die, and sometimes it does, then it goes back up. i also notice that when i am driving, and i come from a 3k+ rpm, and i push in the clutch, it goes way down and wants to die, but then goes back up, and is really annoying, and i have no idea what it is. other than that, the car freaking flies, and someone told me that my head gasket could be blown, but i dont see any signs of it, my oil smells like gas a little bit, but thats the only thing i really notice, and i cant say that i see white smoke, and i dont know if it would have anything to do with this case. The wastegate is supposedly set to 14 pounds, but my car is boosting to 16, idk if that has anything to do with it either. Please give me all ideas and possibly a list of things to check and causes of this problem. I also have 2 t's hooked up for vacuum lines, and at idle when it surges, it goes from -15 to -10 and back again. Please help me guys, i know you cant fail me!
_mickey
_mickey
