syclone typhoon turbo.
They use a Mitsu TD06-17G turbo, but wont fit our applications due to the turbine inlet unless you have a custom manifold made. They flow approx. 550cfm, so it would be a streetable turbo with the appropiate mods. More info Here.
The Sy/Ty's ran a TD06-17C 8cm2. The 8cm housing will not bolt directly to a DSM manifold because the housing uses a T3 style inlet flange, and a 3 bolt outlet like the HRC turbos.
You would be better off picking up one of the many compatiable, commonly used units that our community uses (and has used) over the many years. The two obilgatory questions are: how much do you have to spend? and how fast do you want to go?
EDIT: Someone always beats me to the post.
