AFC # of cylinders
1990talon
331
Aug 3, 2006
Federal Way, Washington
Ok so I bought my car a couple of months ago and I just started to figure out the S-AFC and I noticed it is set on two cylinders should I set it to four or just leave it. It works fine and runs good what should I do?
Ive read it shoud be set to 4cly with the arrow pointing up! Really it should be set at 4 unless this problem is ocuuring! RPM Signal off by half Because of the way that Mitsubishi triggers the ignition coils, this is normal. To fix it, just set the Cylinders to "2"
http://diy.prostreetonline.com/howto/showarticle.asp?articleid=31 Your ne points are sugessted to be set 1000 2000 3000 4000 5000 6000 7000 8000 . Tell you the truth i cant say that it would make a power diffrence but this how all the installs say to set a dsm up.
