CorrupTTalon
- 256
- 1
- Sep 24, 2004
Tampa,
Florida
if you can figure this out youre awesome!
background:
2.3 stroker
nearly stock head
stage three turbo
running nearly NO boost
i do have moble1 syn in it, and im breaking it in.. i have learned that is bad and now im throwing 40weight generic organic crap in.
ive never hit fuel cut but from what ive heard thats what it sounds like.
problem:
it ran decent all day, i put about 15 miles on it. and had it idle for some time. anyways i pull out of a drive and take off on a main road and once i hit second i was at about 5k rpms the thing stops and i hear a noise in the engine.. i immeditately pull over and inspect. it was running like the MAF sensor was unplugged. but nothing had changed.. and it was running like crap.. spitting and sputtering.. i couldnt accellerate past 2k rpm without it bogging down. so i shift it like a baby and was able to get up to 45mph to get it home. pull the plug to find all four BLACK and my pretty new alluminum shiny pistons black and a little WET.. im guessing its running rich because its sputtering and bogging and thats what the wetness was on top of the pistons. it also poofed when i shut it down, not a backfire but im guessing it was fuel left over that exploded in the hot exhaust
anyways if you read that, you are awesome. do you have any suggestions? im gonna do a compression test tomorrow, and pull the pan.. the dip stick looked fine.
thanks in advance
background:
2.3 stroker
nearly stock head
stage three turbo
problem:
thanks in advance
