Tial exgate mbc install
The wastegate source on your MBC goes to the lower port on the external gate (the one on the side). The top port is used for an EBC. Mine doesn't even have the top port.
Hope that helps,
Andy
the other side of the mbc has to go to some sort of boost sorce? right. should i dill a hole in a ic pipe and tap a nipple fiting into it? and run vaccum line to the mbc.??? Can I T into my bov line or a port in the intake mani??????
I don't ever recommend teeing off the BOV line for a boost source. Instead, tap your j-pipe and use that instead. You'll get faster reaction and the ability to hold more stable boost.
Sure, just fix your profile so we know that in the future. Tap as close as you can to the compressor for the best readings and fastest reaction from the MBC.
