hevenz
- 56
- May 27, 2006
Wichita,
Kansas
i was in a hurry running to work and left my headlights on all day (hid's). when i got out of work my car was toatally dead.... i needed a jump. when i jumped my car it started normaly... but somewhere between work and home (6 mi) when i come to a stop it stalls. when i push in the clutch the rpm's drop real low.... some times it dies. some times it doesnt. if it dies while im turning at a intersection and i let go of the clutch the car will start back up... if not i try to start it real fast.... this is like the 10 or 12 time my battewry has been jumped.. did jumping my car last night screw up the battery or is there something else i should be looking at..... please help!!! if i start it from a stop it may or may not die....... but if i hit the gas... the rpm's go up..then the rpms drop to almost one.... then nearly dies...... i was told it might be the BISS. So i do i set the BISS corectly?
