Need HELP
TopDowngst0803
30
Mar 30, 2006
Miami, Florida
Ok I have the MAF Translator on my car an i see the settings theres 2 WOT settings i was wondering what would happen if i set them both to WOT or just one of them. I dont really know what to set it at, any help would be appreciated.
If you set them both to WOT it would mess the the a/f ratio. Do you have the instructions that came with the translator? They should tell you how to set it up according to your mods.
There should be 4 turn dials are(from left to right) Base: This is a global setting to match injector size to the vehicle. Idle: For your idle corection. Mid: This is mostly for setting your cruise map. WOT: Wide Open Throttle setting.
You need to tune it.
