Nonrml4
- 129
- 4
- Dec 11, 2005
Toledo,
Ohio
I installed my Hallman ES manual boost controller this morning. I am using the turbo elbow nipple (1st gen turbo elbow to side mount peice) and the wastegate nipple. I have it installed the correct way per the intructions and the various faqs that I've looked at trying to solve the issue. The issue is that before running boost control through the stock BCS I was hitting 10psi . Now I am hitting 9psi, and there is no change when backing out the knob or tightening the knob. I have removed all of the BCS hoses and the BCS is still in the car with the electrical connection attached. I had no boost leaks before the install and checking now after have no reason to believe that I have any either. All mods are listed in profile. Any input into the situation would be appreaciated, as I am scratching my head at this point.
oops. You were right. Thanks guys
