SkURTnDSM92T
- 122
- 2
- Aug 16, 2006
Cincinnati,
Ohio
This could just be me being paranoid, but at any rate...
The timing belt is right on the edge closest to the valve cover...is this normal? Why would it be settling here instead of right in the middle? All so, the belt is slightly worn on the top edge...the one facing you if you are looking down at the Timing Belt. Im assuming this is normal because of how the belt goes on...the side the lettering and Mitsu part number used to be on. Let me know... thanks
