Is this 14b Still Usable after catching eye on the crack in housing
eclipseism
102
Jul 25, 2006
San Diego, California
Its would defenently be a shame if this 14b was not usable anymore, it has no shaft play what so ever, *EVER*. what you guys think.
It happens to the exhaust housings. Cracks are actually pretty normal. That's a fairly large crack, however. For comparison, here's a closeup of my post-porting 14b exhaust housing. You can see there's a similar crack in the wastegate inlet hole at the bottom:
I would try porting the step off the exhaust housing inlet and see if the crack narrows down the further you go. If not, or if the crack extends to the outside wall, you might want to find another exhaust housing.
It doesn't go all the way through, so it shouldn't affect spool at all. I honestly have no idea when I reach full boost. :)
