highvan
- 85
- 1
- Jun 7, 2006
Warren,
Pennsylvania
Ok, first off, i tried to order two different $60 range boost controllers, one was lost in the mail and the other was never sent, so i got fed up and got a $19, spring and ball type (cheepo) anyways, it comes in today, i get excited
and go put it on, (hook the top on to the hose off my j-pipe and the bottom one to the pipe off my wastegate, is that correct?) I took the other hoses that came off and went to the thing on the top of my aircleaner and just set them aside where my SMIC is, then i just zip-tie it to one of the plastic pieces on my radiator fan, i figured that would be the coolest part to hook it up to, cause everything else gets HOT around that area, is there a better place to mount it? Next, i go test it out, first off, my boost guage goes a bit crazy, weird lag and only goes up to about 10psi and stops, so i stop open the hood, hear a weird crackling sound coming from around manifold/turbo, so turn the screw in a bit, try it again, my boost guage don't show any vac this time and still only goes to 10psi ( i used to get around 13psi before the MBG) so i stop yet again, turn the screw in even more, try it out, still weird boost guage activity and still only shows 10psi??? so i get home, take it out and hook the normal setup back up, so i don't hurt anything... am I doing something wrong here?
