-DSM2NR-
- 602
- 12
- Dec 9, 2005
Tucson,
Arizona
It all started with my battery draining all the time. I would recharge it and after 2 days it would always drain out.
So, I started looking for blown fuses, bad grounds etc.... and found an intersting thing on one of the fuses (one from the engine bay area).
There is a wire connected to the fog light fuse hole and it leads to a separate 15amp fuse which then goes via another wire onto the brake light fuse.
Here's a picture so you guys know exactly what I'm talking about.
This is after I removed the actual wire and fuse. But this illustrates exactly of how they were positioned.
Thinking that this damn fuse and wire combo is causing my battery drainage, I removed it.
And here's the weird part. As soon as I removed the wire and the 15amp fuse my rear lights, dash lights, and radio stopped working. The headlights, brakelights, and windows however still work at this point.
When I reconnect the wires and 15amp fuse everything works normal again..............
I don't know if this makes any difference but the car has a 2gb headlight and front bumper conversion. Disregard the car in my sign. It's my old 97GST
What could be wrong??? Can anybody help me out here?
sorry to bring up more possibilities.
