Compresson Test Results
Passion 4 Speed
198
Jul 26, 2004
kissimmee, Florida
Hey guys i been having a oil burning problem only at idle blue/ grey color smoke, i had my friend watch for smoke coming out from my muffler while driving and flooring it and he said he doesnt see any smoke coming out. So im guessing my valve guides/seals are no good. So i did a compression test my 1st time ever. i followed the instructions on this web site http://www.dsmgrrrl.com/FAQs/compression.htm
I took 3 different type of tests
Turning over for 10 seconds long
From left to right
#1. 185 #2. 200? #3. 175 #4. 175 <<< i tested #2 twice same results
Turning over 4 revs
Left to right
#1. 165 #2. 190 #3. 170 #4. 160
Wet test turning over 4 revs
#1. 205? #2. 200 #3. 190 #4.190<< I tested both 1 and 2, same results
I have 166xxx miles on my motor, and i have a small oil leak coming from the oil pressure sending unit, which i am replacing today , and i have a small crack on my valve cover on the timing belt side which also leaks a small amount of oil. I allways have to add a quart of oil about once every week or 2. Any idea on what could be my problem piston rings or bad valves?? thanks for your help in advance =)
I would say rings.
The oil could be seeping past the rings which would give the illusion of higher compression since its helping the rings seal when cold.
I would say youre experiancing the most blow by on cylinder 2.
thanks for your input..that does make sense about #2, time to start saving up for a jdm motor..does any one know a web site that sells 6 bolt 4g63 motors? i check ebay and they jus sell 90-94 jdm motors, meanig i have a real high chance of gettin a 7-bolt motor unless its ok to swap in a 7-bolt motor??
