nisif
- Dec 9, 2004
Dayton,
Ohio
I bought a 95-99 non-turbo 2.0 motor from the salvage yard to replace my blown motor. After swapping out the crank pulleys I noticed that the motor will only spin about a quarter of a turn. Specifically, the 2.0 label on the exhaust cam will face straight down, and the 2.0 label on the intake cam will face straight up, after rotating it counterclockwise, it will stop at the point where the labels meet with each other (1/4 rotation of the cam gears). I put roughly around 60 ft pounds of torque on it and it won't move. Any ideas, the motor is still under warranty, just want to make sure it's good or bad b4 I put it in. Btw, I took the spark plugs out while doing this.
