1_bar_goes_far
- 40
- Feb 4, 2003
Appleton,
Wisconsin
I did a search for this but found no answer .I was wonting to know how much crankshaft warpadge in ok to have as mine has about .0005 when the crank is setting on the two end bearings and check it in the middle one ,whick makes the front were the balancer goes about
.001 and the same for the rear flywheel matting flang . All of the main bearing looked pretty good for havin 148k on them .This is a 6 bolt turbo engine
