Looking for carrier bearing bushings
krustindumm
118
Oct 17, 2002
My brothers talon is having some problems with the driveshaft *falling out* It doesn't come out all the way, just far enough to leak transfer case fluid. So far our best diagnosis is the bushings that hold the carrier bearings are so worn that it slips backwards. If anyone else has better ideas now would be the time ;) But otherwise we are looking for a source on some urethane replacement bushings.
Does ES make them (or any other company) and where is a good place to buy them (and/or a part number).
Thanks,
-Dustin
I was talking about the ones that hold those brackets to the chassis, but I'll have to check out those bushings too, thanks.
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
    • dhssoccer24
