HELP! I need a part's official name.
trace1227
May 11, 2011
cape girardeau, Missouri
My passenger side door lock wasn't working manually or remotely. I opened the door panel to see what was going on in there and noticed that the plastic piece the lock cylinder is plugged into was not only unattached, but broken. After I moved it around a bit to see if the cylinder was still in place (it wasn't) I used the manual and remote switch to find that neither door lock worked now. WTF. What is the exact name of the piece that the lock cylinder inserts into so I can order a new one? I have tried every site using every possible name and I have had zero luck. Thanks
Trace
Are you talking about the round piece that attaches to it with the wire?
Sent from my PC36100 using Tapatalk
You may actually have better luck locating a parted out 2G and grabbing it off of one. It'll cost less.
Found it. Door lock switch. $39.95 from dealership. Thanks to those that replied.
