FS: 98 GSX 85,000 miles Built & FUN
Ppayer38
317
3
Jul 1, 2009
Smithfield, Virginia
Means of contact: 757-537-2355 (text please) or PM
Price: $7000obo
Wanting something different that is AWD or RWD that looks good that is 300whp= for DD but nto a DSM(Subaru WRX or STI, Honda S2000,Nissan 95+ 240sx, etc, etc)
Just let me know what you have and we can chat...
Description:
98 Mitsubishi Eclipse GSX(Same as Eagle Talon TSI AWD)
85,000 miles on body orginal miles
Have CarFax and KBB on car so you can see them
Built motor(2.3 Stroker - mainly rod/eagle pistons with mitsu 100mm crank) 4000 miles on motor
Ported/polished head with BC spring, retainers, revised lifters, FP2 cams
Custom Tubular manifold for Evo 8/9 style turbo's(Heat wrapped)
Evo 8 MR turbo with 20,xxx miles never above 18psi(the evo it came off of) on eclipse it hasent been over 12-14psi
Custom 2.5" Downpipe to 3" cutout then onto stock cat/catback
Evo 9 injectors(560cc with all new seals) 10,000 miles
Evo IX fuel pump 10,000 miles
Ported 1g TB
1g BOV(uncrushed) 50,000 miles
Stock 2g intake manifold
ACT 2600 PP with 6 puck unsprung friction plate
Fidenza Chromoly Flywheel
New clutch fork, throw out bearing, snap ring for tob, pivotball(shimmed just cause)
Short shifter
Evo 8 shift knob
CNC billet shift bushing
Ball bearing underhood shift bushing
Welded center diff
New brakes and rotors
All new hoses and SS hose clamps
Emissions delete
EvoScan/ECUFlash/Ceddy Mods to tune
1g Koyo Radiator(has dent in the bottom but no leak!) 10,000 miles
VRSF FMIC with short route piping
Stock suspension & components(may come with Tokico struts/Eibach pro spring) slowly replacing
May be Evo IX wheels or stock GST 5 spoke wheels(depends)
Will come with 2gb Talon front bumper cover(black) somce scrates but from previous owner
ALL NEW FLUIDS IN EVERYTHING
All parts have less than 5000 miles on them unless listed differently
The BAD:
Paint isnt in the best shape(have paitn to redo the car just no time)
Suspension components need to be replaced (arnt to bad to drive as I DD the car)
Some rust but mostly surface and very repairable with no holes(1 of the clearer DSM ive seen)
Such an awesome street car and very fun to drive, has a basic tune I did myself with help from tuners but it hasent been pushed close to its limit.. 12psi by 2900-3000rpm so I expect 20-30 by 3400-3500rpm
KBB value is $6000 at lowest price with no mods so this is a GREAT deal for a running DSMl!!!
HAVE LOTS OF EXTRA PARTS AND THEY CAN ALL GO WITH CAR CAR IF YOU WOULD LIKE....
Pictures:
  • For sale 4G63 Pair of fog lights
    Pair of Fiat 500 fogs. Complete with mounting brackets and hardware. Both lens are in really...
  • For sale 4G63 1g/2g Auto Welded Center Diff
    1g/2g Auto Welded Center Diff. Message 702-741-6987.
  • Wanted WTB MSD DIS 2 bypass plug
    As the title states.You must be registered to see element.
    • ist dwa
  • Wanted ISO Extreme Psi weighted shift knob
    Easy peazy…
    • James92
