Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Maintenance & Repairs
Welcome to DSMtuners
Maintenance & Repairs: Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions. Probationary Members can post here.
Reply
LinkBack   Thread Tools
Old 08-12-2012, 06:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Overkill54321's Avatar
Tech Posts: 14
Reputation: Overkill54321 is an unknown
2g rev limit/fuel cut
hey there, i have a 2g with a 2.3 stroker, dsm link v3, that i just rebuilt the motor because it was smoking heavily. anyway i start the car and runs and idles fine and it revs no problem. after about 5 seconds it feels like a fuel cut at 1900-2000 rpm. i can turn the car off and start it again immediatly and it will rev fine again but only for around 5 seconds. what are some things i should start checking?
mark post as helpful recommend reputation points    Reply With Quote
Old 08-12-2012, 06:46 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
Spoolin92GSX's Avatar
Tech Posts: 434
Classifieds Rating: 2
Reputation: Spoolin92GSX is an unknown
A buddy of mine was having a similar issue, his was a leak in the intake pipe between the MAF and turbo. There's the obvious boost leak test, verify settings in your tune, air fuel ratios, etc. Does it do the same thing if you try to drive it or only stopped/free revving? Tried logging to see if all values look about right?
____________________________
-Ryan
6/4 GSX 16G@21psi on 91
Old 08-12-2012, 07:23 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Tech Posts: 14
it happens driving or free reving, i will get a boost leak tester and visually inspect for leaks, it just seemed wierd that it revs fine for a few seconds before the cut happens. i guess given that the engine was out something loose or off is likely. i doubt its the tune as it was running fine before i rebuilt the engine. is resetting the ecu something i should try?
Old 08-12-2012, 07:26 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
Tech Posts: 434
A battery pull couldn't hurt, making sure all sensors are plugged in tight and reading properly and a boost leak test is where I would start.
-Ryan
Old 08-12-2012, 07:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Tech Posts: 14
i will try the battery pull right after breaking bad lol, the car has dsm link v3 on it, will all of those setting stay in the ecu?
will a coolant temp sensor and plug work off an esi if spliced in? i also have one off a 2.5l cirrus.
all i can say is i will never buy someone elses project again.
Old 08-12-2012, 07:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
Tech Posts: 434
Settings shouldn't go anywhere, coolant sensors are only a few bucks I would just get a new one to be on the safe side.
-Ryan
Old 08-12-2012, 08:02 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Tech Posts: 14
the wire came right out of the plastic connector, i will need to splice in a new pigtail
Old 08-12-2012, 11:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
Tech Posts: 434
Junkyard! For the pigtail, if it was me
-Ryan
Old 08-13-2012, 03:09 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Tech Posts: 14
can a leak down tester work for a boost leak tester?
Old 08-13-2012, 03:15 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Proven Member
Sebba's Avatar
Tech Posts: 375
Classifieds Rating: 0
Reputation: Sebba is an unknown
Send a message via AIM to Sebba Send a message via MSN to Sebba
Quote:
Uuuhh, no.
Old 08-13-2012, 03:31 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Tech Posts: 14
snap-on guy came to work and tried to sell me that, said he had never heard of a boost leak tester.
anyway now it also has a misfire, and the problem is much worse when warm.
Old 08-13-2012, 03:45 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Proven Member
Sebba's Avatar
Tech Posts: 375
That's because he's a tool vendor, not a mechanic. You can make a boot leak tester for next to nothing.
Old 08-14-2012, 08:31 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Tech Posts: 14
ok boost leak test done, 3 leaks found and fixed, car runs and idles like a champ, as soon as i tried to drive it i get fuel cut at around 2500rpm while idling or driving.
so what is the next step i should take?
could the ecu or fuel pump be a suspect?
Old 08-14-2012, 08:35 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Proven Member
grothe3297venge's Avatar
Car: 97 Dodge Avenger ES
Tech Posts: 351
Photos: 15
Classifieds Rating: 3
Reputation: grothe3297venge is an unknown
Do you have an upgraded fuel pump?? Those 550's may be pushing your stock pump. (that's insisting you have a stock pump since its not in your bio)
View photos of this member's car
Old 08-14-2012, 08:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
Tech Posts: 14
yea i need to update mods sorry.
yes i have a 255lph, and the car ran fine before the rebuild with the same setup
edit: the problem gets worse when the car is warm. fuel cut happens at 2k
Old 08-14-2012, 09:10 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
Proven Member
Tech Posts: 351
Photos: 15
Only thing I can think of now is you need to post a log so someone can look at your tune!
Old 08-15-2012, 03:24 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #17 (permalink)
Tech Posts: 14
i will do that tonight thanks
Old 08-16-2012, 04:39 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #18 (permalink)
Tech Posts: 14
OK so update:
Problem is gone, i have a feeling it was a bad ground, it was attached to a painted section of the firewall. also fixed a number of other minor things and tested the MAF to make sure that was good. the car idles and revs good. sorta.
im leaning out and getting fuel cut at 8psi. I have updated my mods list for everyone to see.
I do not have an AFPR yet, do you think installing one might solve my problem?
550cc injectors not big enough for my setup?
Will HKS 264 cams affect idle? its minor but noticeable
heres a little log from dsm link, 3rd gear pull. not much there but it shows before the fuel cut and when it happens
http://www.freefilehosting.net/talon3rdgearpull
Last edited by Overkill54321; 08-17-2012 at 04:57 PM. Reason: Auto-merged with previous post to prevent "bumping" within a 24 hour period Tips on avoiding the auto-merge feature - http://www.dsmtuners.com/forums/faq.php?faq=vb_faq#faq_bumping
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.41%
111 Votes
2-5 - 43.60%
126 Votes
6-10 - 10.73%
31 Votes
11-15 - 2.77%
8 Votes
16-20 - 4.50%
13 Votes
Total Votes: 289
You may not vote on this poll.
» Online Users: 963
398 members and 565 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
