| Welcome to DSMtuners |
| Maintenance & Repairs: Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions. Probationary Members can post here. |
06-08-2012, 06:53 PM
Show Printable Version
Email this Post
#1 (permalink)
Proven Member
98 GSX Automatic Idle Problem
Alright guys I posted recently about a different problem with maybe my alternator or battery but I got a new battery in there and it was running fine for the time being. I am confused as to what is going on. The A/T Temp/Brake and Battery light all come on very dim while slowing down or at an idle. And now when I am at an idle my car idles super low around 300rpm and just a few minutes ago it started bogging down and trying to die. I also noticed while driving the throttle response is shitty. I push down like half way and it stays at the same speed for like 5 seconds doing nothing new and then all of the sudden trys taking off like a bat out of hell. Not sure what this is please help!
Anyone know I am getting super worried and irritated just got the car two days ago! I think I am going to get a new alternator have them test it before they put it on and is there anyway to test the voltage regulator in it? Also is there a big 3 upgrade for the dsms if so where can I get it?
Reason: Auto-merged with previous post to prevent "bumping" within a 24 hour period Tips on avoiding the auto-merge feature - http://www.dsmtuners.com/forums/faq.php?faq=vb_faq#faq_bumping
06-09-2012, 06:52 AM
Email this Post
#2 (permalink)
Proven Member
When u rev it, does it want to die and stall out? How many miles and mods on it?
Have you checked the ISC?
06-09-2012, 11:26 AM
Email this Post
#4 (permalink)
Proven Member
What's the IAS stand for I am sorry I am an idiot when it comes to dsms. There is 83,000 miles and I think there are a few mods just not sure what the previous owners did. The last owner that I bought it from took off an aftermarket turbo and put a stock one back on but other than that I am not sure what has been done. There is a boost controller in there so the owner before the guy I bought it from probably did all that. Also I noticed a wire is hard wired to bypass the fuse for the high beams and he put in a fuse labeled 25 when normally for the high beam it should be 10. Not sure what the hell he did.
06-09-2012, 02:55 PM
Email this Post
#5 (permalink)
Proven Member
take car to autozone and have them test it at the battery. I had the same issue and voltage regulator failed. The problem was the alternator fuse (80 amp) on my 1g.
06-09-2012, 03:09 PM
Email this Post
#6 (permalink)
Proven Member
Quote:
Originally Posted by Stmguy42
check isc, throttle body and throttle body cable tension
^^^This is where I would start. Also I would get a hold of the previous owner and see what he tried to do with that high beam issue.
06-11-2012, 11:32 AM
Email this Post
#7 (permalink)
Proven Member
Is this the right connector that I should try and replace?
ACDELCO Part # PT2296
Where can I buy an ISC?
Just replaced the alternator ran fine for a about a day and now it ####s up again going to try replacing the ISC just need part number and best place to buy it.
Also where is the ISC located I have searched a little bit and read a few posts not sure though. Still going to look for more threadds.
07-05-2012, 02:26 PM
Email this Post
#8 (permalink)
Proven Member
I tested the IAC, replaced alternator, replaced battery, and now I am stuck. It only happens when I turn my headlights on and I think it is directly related to the gauges installed on the car! Not sure:/ Going to try taking them out.
» Recent DSM Videos |
» Online Users: 900 |
| 337 members and 563 guests |
| Most users ever online was 1,704, 03-17-2008 at 09:11 PM. |
