Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Maintenance & Repairs
Welcome to DSMtuners
Maintenance & Repairs: Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions. Probationary Members can post here.
Reply
LinkBack   Thread Tools
Old 06-08-2012, 07:21 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
KROMEkid's Avatar
Tech Posts: 15
Photos: 8
Reputation: KROMEkid is an unknown
Question
1995 Eclipse Keeps Dying
A month or two ago the car wouldn't start. It'd turn over for a while but wouldn't ignite at all. I'd let it sit for a few minutes and then it'd start right up.
Now the car tries to die while driving all the time. If I have my foot pressed on the gas it'll just hiccup pretty bad but continue to run.
I replaced the fuel pump about a month ago but I'm having the same problems.
I've narrowed it down to cam or crank position sensor, coolant temp sensor, or possibly fuel relay?
I'm far away from my dad's shop (Where all my tools are) so I can't just pull and test sensors.
Any suggestions? Anyone else have this problem?
1995 Eclipse Gs Only mod is short air intake
View photos of this member's car
mark post as helpful recommend reputation points    Reply With Quote
Old 06-08-2012, 11:19 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Supporting Member
jayson427's Avatar
Tech Posts: 835
Photos: 23
Classifieds Rating: 0
Reputation: jayson427 is more helpful than not
[QUOTE=KROMEkid;153000022]
check your map sensor, vacuum lines and pcv valve. i had that same problem on my old eclipse but i sold it before i fixed it. do you have any cel codes?
Old 06-08-2012, 11:22 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
KROMEkid's Avatar
Tech Posts: 15
Photos: 8
[QUOTE=jayson427;153000175]
Quote:
I did have codes. About 5 or 6. One of which was the "cam/crank pos sensor".
I fixed a bad connection where someone replaced the cam sensor.
Okay so I went to AutoZone and while I was looking under the hood I found a small hole in a vacuum line on the back of the engine, up high. I just replaced it and the engine ran a lot smoother but I still don't think that is what is causing it to shut off.
Old 06-08-2012, 11:28 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
DSM Wiseman
bryanwheat's Avatar
Tech Posts: 5,761
Classified Ads: 1
Classifieds Rating: 35
Send a message via AIM to bryanwheat
If it is still throwing codes than address them. The diagnostic system is there for a reason.
Old 06-12-2012, 12:35 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
95VENG's Avatar
Car: 95 Dodge Avenger 420a
Tech Posts: 19
Photos: 14
Reputation: 95VENG is an unknown
What codes is it throwing? Also Usually want to start out with cheapest. start cam sensor, crank sensor or coil pack. But if its a 420a best chance is cam sensor. I had same prob and thats what it turned out to be. My cam sensor had cracked on the inside so oil was getting into the connection itself and causing it to coat the inside of the connector with oil.
Old 06-12-2012, 04:38 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Proven Member
GSTurbo1's Avatar
Tech Posts: 558
Photos: 35
Reputation: GSTurbo1 is an unknown
Man vacuum lines can play hell on the ECM fuel delivery... I cut one of mine on accident and couldn't figure it out for the life of me. Found out where the sucking noise was coming from in my cabin... put a connector on and it ran like new!
____________________________
1990 TSI AWD... My first 4g63 :)
Old 06-12-2012, 10:50 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
99EclipseGS-Turbo's Avatar
Tech Posts: 19
Reputation: 99EclipseGS-Turbo is an unknown
Have you tried to replace the fuel filter. I had the same issue a little while ago and I figured I would start with the fuel filter since its cheap and easy to replace. So I replaced the fuel filter and it fixed all my issues and never had a problem since. If you have not replaced the filter you have to remove the battery and the windshield washer fluid reservoir. After you remove both of them the fuel filter will be sitting right in front of you, you cant miss it. I hope this helps you with your problems. Good Luck.
Old 06-13-2012, 06:58 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
GSTurbo1's Avatar
Tech Posts: 558
Photos: 35
I have not replaced mine yet... how much do they normally run
Old 06-13-2012, 03:22 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Tech Posts: 19
U can get one at pretty much at any parts store. I purchased mine at autozone. It ran me 25 dollars.
Old 06-13-2012, 04:46 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
KROMEkid's Avatar
Tech Posts: 15
Photos: 8
Alright since I fixed a small vacuum leak the car was running better until today where it died several times and took forever to start. I don't think I can jack the car up high enough to reach the crank pos sensor though :/ Im using the mitsubishi jack.
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.14%
111 Votes
2-5 - 43.30%
126 Votes
6-10 - 11.00%
32 Votes
11-15 - 2.75%
8 Votes
16-20 - 4.81%
14 Votes
Total Votes: 291
You may not vote on this poll.
» Online Users: 913
338 members and 575 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
