Login
Go Back   DSMtuners > DSM Forums > General > Newbie Forum > Maintenance & Repairs
Welcome to DSMtuners
Maintenance & Repairs: Oil choices, timing belt, setting timing, CV boot replacement, alternator servicing, fuse/relay checks, and other basic maintenance, repair and diagnosis discussions. Probationary Members can post here.
Reply
LinkBack   Thread Tools
Old 06-04-2012, 06:55 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #1 (permalink)
Supporting Member
spyderdrifter's Avatar
Car: 1997 Talon TSi Spyder
Tech Posts: 1,363
Photos: 41
Classifieds Rating: 2
Reputation: spyderdrifter is more helpful than not
Can't escape DSM problems....
So, yeah. Only days after getting my baby up and running, it's down yet again. This time it's worse. What's the tell-tale, without a doubt, sure way to know I spun a bearing¿ was heading to pick up a friend, got there, just rev'd the engine once, not hard at all, and when I went into reverse, all I got was a really bad sound like something loose inside the engine. I'm now leaking a little oil from the oil pump, and cyl 3 has an oil leak too. I pulled the valve cover to find nothing unusual, which is how I looked at the pistons, through spark plug wells. I'm lost on this one. Never spun a bearing or had anything loose inside an engine before..
____________________________
-Dag
'97 Talon TSi Spyder (AWD coming soon)
View photos of this member's car
mark post as helpful recommend reputation points    Reply With Quote
Old 06-04-2012, 07:03 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #2 (permalink)
Proven Member
96' Eclipse GS's Avatar
Tech Posts: 557
Classifieds Rating: 0
Reputation: 96' Eclipse GS is an unknown
Well, if you think it is internal problems, put a compression & oil pressure gauge to ensure that it is the problem. Once, then you can drain, drop the (Oil Pan) and start looking for play, metal shaves, etc. Do you have a video that you can post of what you believe is a (spun bearing)?
Old 06-04-2012, 07:07 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #3 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
I got nothing. All I have is the bag of tools in the trunk just in case something did happen (and now it has), but my car is 25 miles from home where my compression tester is. Getting dark so I can't really look til tomorrow after work, ironically where my car is located now.
-Dag
Old 06-04-2012, 07:27 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #4 (permalink)
Proven Member
garrettgoines's Avatar
Tech Posts: 29
Reputation: garrettgoines is an unknown
I would lean towards leaving the car there until you can get tools to check it out. Cranking and cranking and pushing something that possibly broke (as shit) isnt a good idea. Drop the oil pan and plastiguage the rod bearings. Look/magnet for metal in the oil. I just got my first running DSM a month ago and got dealt a broken balance shaft belt/crank angle sensor two weeks ago. Put a brand new $80 crank sensor on it and crack the hell out of it putting on the cam sprocket. Spent $130 on a black top 1G CAS tonight. I knew what these things were about getting into them (but not how to work on them, apparantley!).
Old 06-04-2012, 07:32 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #5 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Yeah, I've already left it. I did try to start it once and only once to see if it was a fluke, but no deal. Got my buddy to help push it. Will be inspecting tomorrow after work. More to come then....
-Dag
Old 06-04-2012, 08:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #6 (permalink)
Supporting Member
crash89's Avatar
Tech Posts: 1,511
Photos: 15
Reputation: crash89 is pretty helpful and trustworthy
If it sounds like this its a rod bearing.. This is my fresh built motor as of last week.. Back to running a stock shortblock..
Spun rod bearing - YouTube
Tom
Old 06-04-2012, 08:06 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #7 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Sounded way worse than that. Wounded more like gear teeth skipping or something.
-Dag
Old 06-04-2012, 08:22 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #8 (permalink)
Proven Member
DSMTyson's Avatar
Tech Posts: 795
Photos: 10
Classifieds Rating: 3
Reputation: DSMTyson is pretty helpful and trustworthy
Oil pump gears is my guess.
Just your average modded '91 Auto TSi AWD
Old 06-04-2012, 08:23 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #9 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Quote:
So for that, would I just be replacing the entire front case?
-Dag
Old 06-05-2012, 04:28 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #10 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
So I was thinking about this on my way to work. My friend suggested that I blew the turbo, but I'm sure I didn't.someone correct me if I'm wrong, but if I blew the turbo, the engine would still run right? There wouldn't be any grinding sounds either I'm sure. Also forgot to mention last night that my timing belt is covered in oil. I'm sure that's kinda important to know....
-Dag
Old 06-05-2012, 04:42 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #11 (permalink)
Proven Member
empie1's Avatar
Tech Posts: 751
Classifieds Rating: 5
Reputation: empie1 is more helpful than not
Quote:
Your friend should stop talking out of his ass. Knocking noises are unrelated to the turbo. You need to drop the oil pan like mentioned earlier. This will immediately tell you if theres bearing damage. Timing belt covered in oil could be a bunch of different leaks...from filter housing gaskets, to oil pump gaskets...even the timing belt tensioner bolt can leak oil (hole goes threw block). It sounds like you are kinda new to cars....either bring it to a knowledgeable mechanic or get a manual and prepare to learn.
Old 06-05-2012, 04:59 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #12 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Quote:
If I was in any kind of way new to cars, I never would have removed this engine from my car, nor rebuild my entire last DSM. Just because I'm having a problem I've never encountered before, doesn't mean I don't know what I'm doing. Please keep those kind or comments to yourself and out of the posts as this is about finding out what's wrong with the car, not people's experience, which I've been working on DSMs for 9 years now. Don't make assumptions about people's knowledge. I will be checking, but can't do much while I'm at work. Just fishing for ideas til I get off work.
-Dag
Old 06-05-2012, 05:27 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #13 (permalink)
Proven Member
chadillac2820's Avatar
Tech Posts: 214
Reputation: chadillac2820 is an unknown
It sounds like (from your description) that the oil pump and/or balance shaft failed. That would crack the front case and explain the noise and oil on your belt. You should tow it home as I don't think you will want to address this problem in your work parking lot.
Old 06-05-2012, 06:25 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #14 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Quote:
Thanks for the suggestion. That sounds quite plausible so I'll be checking the front case for sure.
-Dag
Old 06-06-2012, 04:43 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #15 (permalink)
Proven Member
empie1's Avatar
Tech Posts: 751
. Let me get this straight..youve "worked on dsms for 9 years" and removed a engine, but yet lack the common sense to troubleshoot a knocking noise? Someone with knowledge like you claim to possess would compression test than drop the oil pan to start. Its common sense. Dont get your panties in a bunch cause you dont know that much about engine internal operation. The fact that you posted about the turbo being a possibility says a lot about how much you know. Dont post things on the internet and cry when you get a response you dont want to hear. You are clearly no expert on engines...maybe do some searching and learn a little before you run your mouth.
Old 06-06-2012, 05:22 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #16 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Ok guy, one, I didn't say the turbo was a possibility, I simply stated the my friend asked if it was. I told him no, because I know the engine would still run had I blown the turbo. I do research things quite often and learn things all the time. Two, I NEVER claimed to be an expert on engines. Had I made that claim, I wouldn't need this forum, or be asking any of you for help. There's no 'lack of common sense' on my part. I had a good idea of how to trouble shoot this problem despite never having this problem in 9 years. I simply didn't have my compression tester with me, how many people do you know that carry those in their back pockets? In addition to that, I'm not gonna get bitched at for dumping my oil out on the ground just to remove my oil pan. I don't carry my drip pan in my back pocket either. This is all stuff I'd be doing regardless of your pointless insults once I get my car back home.
You claim I'm just running my mouth when all I've done is seek help, and defend myself against your pointless post that didn't offer any kind of positive help. And it's not a knocking noise, if you've read my posts, it's a grinding noise. In fact, YOU'RE the only one in this thread who's said anything about a knocking noise. I think you need to learn to read everything before you talk out your ass. This makes me question your knowledge. So from here on, please keep your comments to yourself and don't post on my threads.....
Oh, you also have a few grammar and punctuation errors in your post, which I do believe is a violation of the posting rules.... you might want to check that out I count 9 in punctuation, spelling, and wrong context. Plus there are two in your first post. Please correct yourself before trying to correct others. Don't flame me when you got some work to do on yourself first.
-Dag
Old 06-06-2012, 06:40 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #17 (permalink)
Proven Member
empie1's Avatar
Tech Posts: 751
Hahahahahahaha!! I could careless if you question my knowledge. I know my stuff and my car is the proof. For the record dummy, maybe re read what you typed in the first post, than read what everyone has said. I have zero respect for ignorance. Since your one of the obnoxious ones that likes to play the "forum rules card" as self defense, I'll oblige! Use the effing search feature and do some work before posting retarded threads. You could have At least found starting points for diagnosing your problem. Regardless if you understand how the actual engine operates, its common sense. Search, troubleshoot than post. Almost every problem you could run into with these cars has more than likely covered some where on the forum.
Btw do you honestly think anyone really gives a #### about you pointing out grammar mistakes?? Lol!!! Good one "guy". You got me. I'm stupid.lol
Old 06-06-2012, 08:37 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #18 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Again, I did ask you to keep your retarded comments to yourself since they do not add insightful help to this posting. If you wish to call yourself stupid, that's your problem, but don't call me the dummy. I've been quite nice about this and wish to have no further dialogue with you on here. I have zero respect for those that wish to ensue in pointless comments to insult others who only ask for help. Don't judge me, but instead take a long look in the mirror and judge yourself.
-Dag
Old 06-06-2012, 09:51 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #19 (permalink)
Proven Member
DSM1G90's Avatar
Tech Posts: 3,824
Photos: 7
Reputation: DSM1G90 is extremely helpful and trustworthyDSM1G90 is extremely helpful and trustworthyDSM1G90 is extremely helpful and trustworthy
Better watch out for flaming other members on here.
empie1 is no better than anyone else if he's making claims like that
Let's all just work together to have fun and help out in this forum-why we're on here.
Things happen to all of us like me blowing up an ECU when I accidently shorted out a sensor...and don't tell me that empie1 didn't have his share of mistakes.
I commend Spyder for at least trying his best, for I've never done a motor rebuild on my own outside of helping others with the same task.
I'm more into the timing aspect with the motor.
-DSM
Old 06-07-2012, 08:50 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #20 (permalink)
Retired
LandoAWD's Avatar
Car: 2012 Genesis Coupe
Tech Posts: 4,136
Photos: 29
Classifieds Rating: 12
Reputation: LandoAWD is an experienced, knowledgeable member worth listening toLandoAWD is an experienced, knowledgeable member worth listening toLandoAWD is an experienced, knowledgeable member worth listening toLandoAWD is an experienced, knowledgeable member worth listening toLandoAWD is an experienced, knowledgeable member worth listening toLandoAWD is an experienced, knowledgeable member worth listening to
Send a message via AIM to LandoAWD
Both of you need to cut the shit. Period.
No more warnings.
Kris
2012 Hyundai Genesis 2.0T
Old 06-07-2012, 09:22 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #21 (permalink)
Proven Member
DuricsmitGST's Avatar
Tech Posts: 33
Reputation: DuricsmitGST is an unknown
That was entertaining...did you get the car home yet? I'm curious to know what failed. you said this is your new engine... is it possible that an internal bolt came loose? my buddies evo had a loose oil squirter on his fresh 2.3 build.
Old 06-07-2012, 11:42 AM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #22 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Quote:
No, haven't gotten it home yet. Called off work yesterday so I could catch up on sleep for once, so that didn't get me anywhere with my car. It's the original engine, all I did was replace the water pump, head gasket, and timing belt. Didn't remove anything from the head, or the block other than the accessory components, timing parts, and oil pan. Until I get my car home, anything is possible.
Getting it home tonight.
-Dag
Old 06-07-2012, 02:55 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #23 (permalink)
Proven Member
DSM1G90's Avatar
Tech Posts: 3,824
Photos: 7
Good luck as always. - DSM
Old 06-07-2012, 03:04 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #24 (permalink)
igluna's Avatar
Car: 2001 jaguar xjr
Tech Posts: 1
Reputation: igluna is an unknown
why did you replace the head gasket? Maybe coolant mixing with the oil wore the bearing prematurely?
Old 06-07-2012, 03:20 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #25 (permalink)
DSM Wiseman
WES_393's Avatar
Tech Posts: 2,460
Photos: 13
Classified Ads: 1
Classifieds Rating: 6
Seems like it's time to drain the oil and search for metal flakes. If you find any, I would drop the pan and check the bearings. Unfortunately that's really the next step to take. If you need any assistance, let me know.
-Wes M
16g/E85- 12.7@108
H1E/E85- 13.2@105
Old 06-07-2012, 03:27 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #26 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Thanks guys, will be draining and dropping the oil pan, then sift through with my magnet. Will be looking at the bearings and oil pump/ front case as well. Igluna, I replaced the gasket just for the sake of being able to know the age of it, same as with the timing belt. Didn't want to go through the hassle of replacing the water pump and have one of the others go out soon after. Just a preventive measure on my part.
-Dag
Old 06-07-2012, 03:39 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #27 (permalink)
DSM Wiseman
WES_393's Avatar
Tech Posts: 2,460
Photos: 13
Classified Ads: 1
One other thing to check before you tear off the pan: Make sure your crank pulley is still bolted on tight. I had mine nearly fall off while driving down the road which made it thump against the engine bay. It sounded very much like a spun bearing, but only took a 12mm wrench and a few minutes to fix.
-Wes M
16g/E85- 12.7@108
H1E/E85- 13.2@105
Old 06-07-2012, 05:20 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #28 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Quote:
Good call. I had a similar problem on my last Spyder, but I broke the crank pulley. Car should be home shortly. Just got her on the trailer. I'll definitely check that out first.
-Dag
Old 06-07-2012, 05:31 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #29 (permalink)
Proven Member
rEclipserGST's Avatar
Tech Posts: 1,255
Photos: 41
Classified Ads: 1
Classifieds Rating: 37
Reputation: rEclipserGST is an unknown
Send a message via AIM to rEclipserGST Send a message via Yahoo to rEclipserGST
Check for shaft play in & out, side to side on turbo.
Check the harmonic balancer (crank pulley). Could be bolted on tight, but the rubber could have separated in the inside. Must remove to inspect.
I probably would have pulled the head before the oil pan honestly. Either way, on to the next.
Check to make sure the rockers & lifters are functional. Pitting on pistons & other obvious signs of abnormal wear.
Check flywheel & pressure plate even. Bolts caught in there could make terrible noise.
Visit rEclipserGST's homepage!  View photos of this member's car
Old 06-07-2012, 08:34 PM Show Printable Version Show Printable Version   Email this Post to a Friend Email this Post      #30 (permalink)
Supporting Member
Tech Posts: 1,363
Photos: 41
Well, my rear balance shaft sprocket didn't have the bolt in place and bored a hole through the timing cover, which explains the scrapping sound I had, which cause the timing to jump. I can move my intake cam by hand even with the timing belt on, so my valves are most likely shot. Pulling my engine out tomorrow and tearing it down to see what all is damaged. Upgrades will soon follow along with a trip to the machine shop.
-Dag
Reply
Bookmarks
Thread Tools
» Recent DSM Videos
1gb AEM wastegate hood dump 2step
» Recent DSM Photo
Post your banner here
» Current Poll
How many times have you been to the Shootout?
1 - 38.14%
111 Votes
2-5 - 43.30%
126 Votes
6-10 - 11.00%
32 Votes
11-15 - 2.75%
8 Votes
16-20 - 4.81%
14 Votes
Total Votes: 291
You may not vote on this poll.
» Online Users: 655
265 members and 390 guests
Most users ever online was 1,704, 03-17-2008 at 09:11 PM.
DSMtuners Main Sections
DSM Forums
DSM Regional Forums
DSM Builds/Journals
DSM Articles
DSM Tech Guides
DSM Upgrade Paths
DSM Parts Reviews
DSM Vendor Reviews
DSM Classifieds
DSM Parts Guides
DSM Photos
DSM Videos
DSM Timeslips
DSM Dyno Sheets
Shirts & Apparel
DSMtuners Decals
Advertising Info
Our Sponsors
Site Rules
Terms of Service
Privacy Policy
Site FAQ
About Us
Contact Us
